[Moved] A small circuit explanation(from circuit theory)
visva
Member level 3
Member level 3
i have marked in the following circuit what i have doubt. In that circuit why there is no voltage drop across 12ohm.
There is not current path so no current. The two ends of the resistor are connected to circuitry which is 'floating'.
Keith
a 10 v source is connected in series to an with a 1 ohm resistor and 1 h inductor at t=0,the current in the circuit is ...??
10+10 exp 100t
10-10 exp 100t
10+10 exp -100t
10-10 exp -100t
