[Moved] 7-segment display multiplexing frequency and duty cycle
imranahmed
Advanced Member level 3
Karachi,Pakistan
Please let me know that what is the duty cycle and frequency for 7-segment display showing digits without flickering?
Re: 7-segment display multiplexing frequency and duty cycle
if possible, I think you can use latches to avoid flickering.. just single time data sending no need of keep sending..:)
Please if you have more information about multiplexing 7-segment display more than 2 so please guide me i am using Atmel 89c52 microcontroller.
you can use transistors as switch or you can use 4094 chip(8 bit shift register) to drive three display.. what do you actually want?? I mean what is your application??
regards:)
With out proper description of the application there is no point you will be able to get prper op here
if you are using proteus.. I've attached a demo of connecting multiple seven segment on same port.
since I was in trouble at my project to find solution like this easy problem.
so, I don't want you to do same..:)
View attachment help seven.zip
Separate segments can not work but 4 pair of seven segment display work well and i can run successfully.You can see in attached pic.
Dear samuel,
I want to build digital voltmeter for displaying 220v by using Atmel 89c52 uC and I have successfully multiplex 4 7-segment display but problem is that conversion of hex data into its corresponding 7-segment data.I can attached ADC0804 both are run successfully but how I implement to display 0-220v,there are 0-to-220 (221v) values, I was write c-code but it become large.Please i need some hint for my project.I attached proteus file and c code and hex file.
  • 7-seg+ADC+code.txt
  • voltmtr.txt
