chiques
Full Member level 3
- Joined
- Nov 21, 2007
- Messages
- 170
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- California
- Activity points
- 2,556
Hello Everyone,
I have a project that I’m working on which involves installing a USB power source in my 2003 vehicle. I searched ebay and found a nice looking socket from China which was advertised to provide 5VDC @ ~1.55 A for each port. I went ahead and purchased it and installed it. I required me routing out one of my dash panels. The installed product looked very nice and clean. I plugged in my phone and my phone external power icon showed a connection. But there was a problem.
I found my phone was randomly making the tone that it makes when the external USB power jack is disconnected and reconnected. I got a bit suspicious decided to check the load current vs voltage drop using an older potentiometer. I rigged some USB male and female connectors so I can splice into the circuit path. I basically slowly minimized the resistance of the POT, connected 1 –DMM as a current meter and the 2-DMM to measure the voltage across the USB port. I found something that was bit concerning.
As I lowered the resistance on the POT, I saw the current rise and voltage drop. The product was actually only able to provide 150mA before dropping below 4.75V (the low end of the USB spec). I contacted the seller and basically they want to send a replacement. I’m a bit sketchy now because I don’t think this is a defect but a poor design.
I was determined to have my 5VDC USB jack in my car so I decided to take a look at a linear voltage regulator. In this case I purchased some LM1084IT-5’s from Digikey. I tested these under the same load circuit and drew 2A @ 4.99V then my potentiometer started smoking. The regulator didn’t heat up to the touch either.
My question:
Is this the proper way to validate the current specification? Are linear power supplies and switched power supplies tested in the same manner? If so, this just means that these types of Chinese electronics are way over spec’d on ebay.
Any insight or advise is greatly appreciated.
My question:
