danger_dan46819
Newbie level 3
- Joined
- Jan 10, 2010
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Ft Wayne Indiana
- Activity points
- 1,317
I am trying to remove the 9 Volt battery and replace it with a voltage divider on a garage remote control so I can work the remote from my Honda Goldwing Push to talk switch. I first took the battery out made a voltage divider jumped the switch and the remote would not work I reinstalled the battery it would not open the door until I disconnected the battery. I then took the jumper off the switch removed the switch
ran two wires to the PTT on the bike and it worked. Next I reinstalled the voltage divider ( I get the required 9 Volts all the way to the circuit board). It will not actuate the door. Am I not getting enough amperage? I could only find a 1000K 1/4 watt and a 3300 K 1/4 watt at the local Radio Shack. SO I am actually getting 9.69 volts. I ran the Voltage divider off a switched accessory circuit on the bike so it won't drain the battery when not in use.
SO I have 9 Volts I have the PTT switch working but it won't work with the voltage divider...This is the extent of my Electronics knowledge. I am a pretty good electrician..
Need some help on this one!
