Dogbreath97
I'm having some problems with my mosfet (IRF840 Vds 500V). Im trying to get a 230V motor working with a 3.3V signal from a raspberry pi. I've included the schematic. The GPIO.OUT is the output of the raspberry pi. When the 100K resistor is in place the mosfet seems to be turned 'off'. When I remove the 100K resistor the mosfet is turned 'on'.
When I have the 100K resistor in place and an output of 3.3V of the GPIO the Fet is still turned 'off', I was wondering if someone knows what I might be doing wrong...
My circuit:
Also, which program should I use for making schematics? I used paint for the one above (not great as you might see)
My circuit:
