samppa
Newbie level 5
Hi everyone,
I have noticed that with modern consumer electronics, the switching mode power supply is almost always the weakest part regarding realiability. However, the laws and regulations are continously pushing designers from linear power supplies to SMPS because of energy effeciency. This means that we are forced to use SMPS even in devices that should reliably last for more than a couple of years. I am particulary worried about white goods, for example intelligent refridgerators, electric stoves/ovens, coffee machines, etc...
I have decided to start learning some SMPS design basics by building a simple 230VAC -> 5VDC, 5-10W power supply and thought that it would be interesting to try to optimize for reliability from the beginning. So, I present a couple of questions for the more experienced designers and hope to get some feedback.
1) What do you think are the weakest components in a SMPS of this power level? I think we all can agree that the electrolytic capacitors (in secondary circuit) are statistically the weakest link, but what comes after them? Maybe optocouplers because of their LED aging? What about the other components like diodes, ICs and FETs, do you think that we can list them in an order of "general" reliability?
2) What is the most reliable topology for this kind of SMPS? I found this primary-side regulated flyback configuration:
hxxp://www.powerint.com/sites/default/files/PDFFiles/rdr158.pdf
This looks very good to me because there is no optocoupler (one less failure prone component) and the overall component count is very low. But what is the catch? Why do almost all SMPS have an optocoupler? Is it just for saving money on the simpler transformer?
3) Even with all things considered and using high quality electrolytics, do you think that a SMPS will ever be able to reach the respectable 15-20 years of service life of a well designed linear power supply?
