DM0119
Newbie
After a look in deep in the attached photos the switching curves of the gates,and i am wondering if this switching is acceptable for work MOSFET in spwm H bridge LF inverter.I would like your general opinion on all points and your suggestion for some improvement.
Details for the system:
.Dead time at 1 μs for test reasons
.Driver IC ir2113s
.Totem pole gate driver amplifier 7 amps with mosfet.(Attached photo)
.Power mosfets FDH055N15A (6 in parallel)
.Rg is 6.8 ohm (for each mosfet)
.Rgs is 33 kohm ( for each mosfet)
.I use antiparallel diodes for each.
Thank you in advance !
.Driver IC ir2113s
