Ethan25
Junior Member level 2
I'm planning to integrate my pH sensor and TDS Sensor together to an ESP32 board but I read that both the sensors should not be operated together as the ground looping effect would disrupt the readings. So I'm planning to use a MOSFET in a switch configuration so at a given time only one of them would be on the other would be off.
there were analog isolators available in the market but those are expensive and I think this is a pretty neat alternative ? I would like to know if this a good solution or If my assumptions are wrong anywhere
thanks.
thanks.
