circuitking
Full Member level 5
Hi I was reading this document and came across some confusion.
https://www.uio.no/studier/emner/matnat/ifi/INF4420/v11/diverse/Extracting_uCox.pdf
https://www.google.com/search?q=cap...UIECgB&biw=1360&bih=625#imgrc=x0OqxKbzpedvkM:
1.As per the above curve, MOS capacitance is small in depletion mode (when 0<Vgs<Vt) and weak inversion (I don't know exact range for this). Bandwidth represents the speed of the device and BW is inversely proportional to the capactiance. Hence, the speed of the MOSFET should be more in depletion mode and weak inversion mode
2.When Vgs>Vt, the MOSFET enters into strong inversion mode (Saturation region). Then based on chose Vgs value Id is driven, which decides the Power consumed by the device. The more is the chosen Vgs, the more will be power consumption. In this the MOS capacitance is higher than the above case, so less speed.
But in the document it is said that
Always put your transistor in moderate-inversion region (V OV ≈ 150-250 mV) to make a compromise between speed and power consumption. If you need more speed → Strong inversion region. If you want low power → weak inversion
Can someone tell me
1.what are exact range for weak, moderate and strong inversion modes.
2.As per my argument, we get more speed in depletion or weak inversion mode but as per the document it is strong inversion region. Which is correct and why?
Can someone tell me
