MOSFET sizing (channel length) in cadence
ansonyeap
Member level 2
Member level 2
MOSFET sizing
Hello. I doing some analog IC design simulation using cadence. but the transistor size that the library have is too small(in term of channel length) for my design. i need a larger channel length.
My question is how do I connected the smaller transistors in series so that i get can get the channel length i want? i know that connecting smaller transistors in parallel will increase the width. thank you.
MOSFET sizing
Are you saying that you can't edit the properties to change L?
I have never seen such a limitation before.
Re: MOSFET sizing
ya. I can not edit both the width and length. The software didn't allow to do so. so any suggestion on how to obtain the length that required? thank..
Re: MOSFET sizing
you can put the mosfets in series to get the L you want, but it is better to adjust L in your model
Re: MOSFET sizing
as I know paralleling the transistor can only make the width wider right? but the length is still fixed right?
I not really get what you mean... can you explain more on how to parallel the transistor can vary the length? thank you...
MOSFET sizing
I blieve taht transisitor lenght cant be changes however we connect it .. parallel or series.. only effective will be altered......
Please correct me if I am wrong....
MOSFET sizing
connecting identical transistors in series will increase L
connecting identical transistors in parallel will increase W
Reactions: skoda
    skoda
MOSFET sizing
Placing transistors parallelly will only increase the width of the transistor but not the length. To increase the length the transistors (fingers) have to be connected in series in concept . To check the max length you can get for a transistor you can check in the cdf callback or the model file. If you are using a particular technology for your design you cannot cross the limits of length or width pertaining to that technology.
