Mosfet selection for high ampere application
varunme
Advanced Member level 3
for the order of 60A, which MOSFET will be suitable in parallel?
You have not mentioned d voltage rating...u can use
1)IRFZ48(60V,50amp,Ron=.018ohm)
2)IRF540(100V,28amp,Ron=.077ohm)
3)APT5025BN(500V,23amp,Ron=.25ohm)
If u r planning to use a single module instead of paralleling,u can use
1)APT10M25BNR(100V,75amp,Ron=.025ohm)
Reactions: varunme
    varunme
If the frequency of the switching is of the order of 100Khz can we used these mosfet?
Manufacturers and distributors have interactive selection guides.
There you will finde the right device.
Klaus
Reactions: varunme
    varunme
