MOSFET saturation in cadence
ncj
Junior Member level 1
i am a beginner in Cadence and trying to design a 2 stage MOSfet. Is it necessary that all stages should operate in saturation region for amplification..plz help...
what do you mean by 2 stage mosfet?
or do you mean a two-stage amplifier...yes all the
transistors need to be operating in saturation for you to achieve high gain..
Reactions: ncj
    ncj
thank you....and i am having difficulty in making them all in saturation....plz help with some solutions...
you can try to keep them all in saturation by allotting atleast 100mV overdrive
across each transistor...you should also use good biasing schemes(high swing biasing) to bias
the transistors..
what type of topology is the 2 stage amplifier?
No, you can get gain in the linear or transition regions - just not as
much, or as consistent.
A high bandwidth amp may work better with the front end load
mirror not-saturated - bandwidth tends to drop as DC gain goes
up (an artifact primarily of the low current needed to stay in
saturation).
An op amp that depends on the high (ideal) Rout of all the FETs
in few stages, is most likely to disappoint in its AVOL. Simple is
nice, but often depends on perfection too much.
yes...dick_freebird is right in saying that gain can be achieved with
transistors in linear or transition region, but it won't be high enough...
and the bandwidth and gain will be a tradeoff...we will have to lose
some of one thing to achieve the other...
Reactions: ncj
    ncj
