Mosfet reverse voltage protection
edmundopt
hello
I'm searcing for Mosfet to use as reverse voltage protection, without extra components, the voltage is of 12volts and the maximum current is of 7amps.
I have found the FQPF47P06 and I'm concerned about the value of Gate-Source voltage, in the datasheet it is only mentioned in the Absolute maximum ratings part, and the value is of +-24volts, so will it handle the 12volts reverse voltage ?
Any sugestions for other models ?
If I want a Mosfet for 24volts reverse voltage protection withou adding extra componentes, wich value should I use for Gate-Source voltage?
