Salvador12
Full Member level 4
Hey, I am building a mosfet output relay for my amplifier, but as we know in case the relay opens while there is significant current through the load , with an open circuit the current will have no where to go and there will be a voltage spike that can destroy the speakers and the output mosfet itself. Speaker passive filters can store significant energy in the coils.
Therefore I am thinking to use an additional element , a switch that would close (short circuit) the output everytime the mosfet relay opens up.
Can you folks suggest what would be the best type of semiconductor to use for this purpose and how to implement it in my existing circuitry?
My current best bet would be a TRIAC/GTO .
As you can see in the attached picture I have an opamp driving a BJT which provides power or cuts off power to the isolated mosfet driver IC. My idea is that the moment the mosfet driver IC loses power and the mosfet gate charge drains , there should be the closing of the shunt switch to short circuit the output.
The shunt doesn't have to be exactly short circuit, I think I would implement some 8 ohm or bit higher resistor in series with the switch to limit current while providing extra power dissipation.
