[SOLVED] MOSFET instead of planar resistors
Zak28
Advanced Member level 2
Is it fine to employ to220/247/3P MOSFETs as resistors inplace of similarly packaged planar resistors for constant loads and for switched loads?
The NMOS would be biased with a precision pot at its gate using a DMM from power supply to drain to make the current precise.
Constant load.
Switched load.
1. Don't expect stable current in this circuit due to temperature dependent Vgs/Id characteristic. Some kind of feedback suggested.
2. Consider reduced power rating of MOSFET in linear mode caused by inhomogeneous current distribution. Check SOA in datasheet.
Reactions: Zak28
    Zak28
What feedback arrangements are there without high speed opamps?
