MOSFET Gate starts to oscillate at Miller Plateau.
vignesh4488
Newbie
Newbie level 2
My circuit is actually used for current sensing. I have provided the overall circuit for reference.
I am facing a gate oscillation issue at 24Mhz when the MOSFET begins to conduct at threshold.
I have attached the waveform and schematic for your reference.
Green -Gate Of MOSFET Orange- Vds
MOSFET used: UF3SC120040B7S
Input voltage: 35V
Please provide your suggestions regarding the above problem.
Regards,
Vignesh.
the schematic may be from a simulation ... I don´t expect it to oscillate.
I rather expect the real circuit to oscillate.
--> Please calrify.
If so, I xpect a bad PCB layout / bad wiring / bad part selection to be the root cuase for the oscillation.
Klaus
I have probed gate and drain of MOSFET.
Layout: Source of MOSFET is routed longer followed by one 0.47uF capacitor.
Actual my circuit is to work on 350V. When I have turned on MOSFET with 350V, D-S are shorted.
So, I have started debugging with 35Vdc but still oscillation in D-S and G-S.
I have also gone through some research paper on online they have mentioned oscillation because of source inductance. In CSR has inductance of 5nH therefore I have shorted that tested and same problem exists.
Another one question, How to calculate PCB trace inductance and any idea on that?
Regards,
Vignesh.
1nH/mm is roughly right but coupling is anyone's guess. And that's the big deal, where is your feedback, your gain and your phase shift? About the only a priori "knowns" are rough Cgx and rough gain vs OP for one path.
you already posted megabytes of scope pictures ... why not a photo of your circuit - including the scope connections? (100kBytes should be sufficient.)
Klaus
Write your reply...
LaTeX Commands Quick-Menu:
