manju_bhat
Junior Member level 3
mosfet gate driver
Hi All
I am using LTC3810 in one of my application.
As given in the datasheet ,I used Si7852 / Si7174 MOSFETs as TOP and BOTTOM Mosfets.
My Input is 24V ( range is 21v to 62v)and Out put is 12v @ 3A and switching frequency is 250Khz. This gives us duty cycle of 50% at Swithcing node.
I got very clean switching node waveform.
My application also include 12V at higher load that is 12v @ 7A.
But since Si7852 or Si7174 used to get heated up when 7A load was connected.
So I changed the MOSFETs and used D2PAK MOSFET . That is ST micro electronics make STB160N75F3.
but in this case , I have output 12V ,not a problem. But when i looked into Switching node waveform (Vin=24v)
The wavform is getting corrupted fully. I was expecting a duty cycle of 50% here.
What could be the problem ? Is the gate charge capacitan ?drain to source capacitnce ?
why i am not getting pure duty cycle of 50% with 250khz as frequency ?
One thing i should say is , since original MOSFET was POwerPAk-8 , and now i am using D2PAK , i made some jumper and cutting on the board.
is that the problem ??
I have attached my circuit here.
thanks in advance
Hi All
thanks in advance
