mosfet driver circuit for audio amplifier
torpedo2k3
Newbie level 3
Newbie level 3
united kingdom
mosfet driver
hello
i want to build a gate drive circuit( without using driver IC) for two mosfet that are to be placed at tranformer secondary winding of LLC resonant converter instead of normal pn diode.Mosfets are required to turnon and turn off alternatively (much like full bridge rectifier ) with changing polarity of center tapped transformer (24 volt secondary )...any idea or any webpage to tell how to make this driver circuit ?Thanks
thanks .will this circuit work on secondary of center tap transformer to drive mosfets where voltage is sinosidal:| ? how can i use this circuit to drive two N-Mosfet (for synchronous rectification ) instead of one NMosfet and one PMosfter combo ????...
mosfet driver circuits
Sinusoidal? You mean to drive the mosfets 'analog' like in an audio amplifier?
Normally the 2 N-ch mosfets are connected to ground with the sources.
The centertap is connected to the positive supply.
Each mosfet willl pull the transformer winding to ground one by one.
totem pole mosfet driver
hi ...not to drive mosfets with sinosidal signal ..i attached the circuit diagram to elablorate my question. i mean with positive sine half cycle ,upper mosfet will need to be turn On ...and other half cycle ,bottom mosfet will turn On (much like full bridge rectifier )..but i need driver/control circuit which will provide synchronization between secondary sine voltage to application of gate signal to ensure right mosfet get On at the right time ..
driver circuit mosfet
the drivers are designed in compensated manner, or by a single driver. so its fully based on Spec
driver circuit for mosfet
You can place comperators like LM393 from (output) minus to the transformer ends followed by a totempole .
The upper comperator drives the lower mosfet and vice versa .
You can do the same with transistors using a emmitercoupled schmitt trigger followed by a totempole .
When the upperside is positive you switch the lower mosfet & vice versa .
Its not that hard ,just make sure your comperator doesnt get fried ,so do use resistors to sense the transformer .
Good luck .
