MOSFET Control problem with PIC PWM Signal
jean12
Advanced Member level 2
Hello,can some body tell me what I can do for controlling my MOSFET here,I am applying a controlling signal but I don't get the output but the MOSFET are becoming highly hot.
Please Help.
Thanks.
  • Schema.pdf
Your H-Bridge Circuit is wrong. http://www.talkingelectronics.com/projects/H-Bridge/H-Bridge-1.html
You have to use 2 pairs of N and P Channel MOSFETS. Study how H bridge works. One N-Channel and One P-Channel MOSFET will be active at a time.
Where is the bias voltage for the MOSFETS? MOSFETS need a reverse voltage for the gate. Use design 6 from the above link.
The opto isolator is HV400IP ,the signal is being generated by a Microcontroller PIC16F1827 using Tahmid blog ,it is generating two signals of 50Hz and 2 signals of 20KHz so those four are applied on the gate of the MOSFETs;when applying the signal the MOSFET (IRFP460) became very hot.
Please help.
Thanks
hello Jean, Can get an idea from this ,try
So how can you help me with the MSOFET of the same types in H_Bridge??
Thanks.
Reactions: bandu
    bandu
Jean, One of my friend gave this note ,he said, he also download it from net ,this is PIC driving motor circuit, I think this may be helpful to you.
bandu.
  • P9-059.pdf
Jean ,read this page to get an idea
Bandu
Me I am using HV400 as drive and MOSFET IRFP 460;the PIC16F1827 is giving PWM signal of 20KHZ and 50Hz .
Can you please help me to think far on this implementation??
Thanks,please help
jean see this
bandu
Hello I am using only N-Type MOSFET?and I found that it is possible to use them so help me with that.
jean .Did you find any solution ,for your mosfet control?
bandu
No,I didn't.
Please help.
