abicash
Member level 3
Hi
I am trying to build a constant current Electronic Pulsed load for 0-5A dc.
Pulse width(single) is settable from 5mS to 1S. The current magnitude is set via a DAC of up to 5V corresponding to 5A.
The Load is a resistive load. MOSFET is mounted on a big solid heatsink.
Please find the schematic attached for reference.
I have tested the current pulse up to 5A for a compliance voltage of 30V. It works fine (perfect square wave voltage across the load) for various pulse widths. (Pulse width is one time for one switch press)
Now I had to increase the compliance voltage to 95 V for a load of up to 19 ohms.
Now when I send a pulse of 100mS for a current of 1A , the MOSFET shorted across all Gate, Drain, & Source.
I observed a square wave starting at 0 , then completing its 100mS for a straight line and at turn off , the voltage across the load shot north on the DSO.
What did I do wrong?
What do I need to correct for this to work?
Please help!
Please help!
