siegmar
Newbie level 2
mosfet leakage current
Hello people
I have a small problem and maybe somebody has a better solution.
A 15 nF capacitor is charged on 450 V.
The capacitor should be discharged over a resistor of 4.7 Mohm in 100 µs impulses.
Unfortunately, the Drain to Source Leakage Current of the body diode of the MOSFET's is too high !!
Is a high voltage BJT transistor a better solution or I have simular problems with Leakage current? I can found nothing about this Leakage Current in the data sheet's.
Maybe the High Voltage transistor FMMT 459 is the right part ? The Vce (sat) is only 70mV, but nothing is written about the Leakage Current or I am blindly.
I have to order some samples for testing. But maybe I am wrong and a better solution is possible.
IGBT without a Body Diode ?
Another solution is maybe an HV relay. But I found only relay with a 1 ms switch time.
Are faster relay's on the market ?
Thanks in advance and have a nice day !
With best of all regards
Siegmar
Hello people
Siegmar
