TXRX
Full Member level 2
I Attached schema with 3 MOSFETs that prevent from capacitors C34, C35 to charge at 3 different time interval.
Do you think that MOSFETs can be damaged from from differnet timing of satuartion for each MOSFET ?
I put a Diodes that protect from situation that the capacitors charge for voltage and the MOSFET will discharge the capacitors and will develop a peak of current at MOSFET.
Thanks,
Doron
Thanks,
Doron
