vishweshgm
Member level 4
I want to drive a 3kW resistive loadusing Mosfet dimmer circuit. Circuit I plan to use is the following:
Please ignore the 555 circuit part. I will be replacing it with a mosfet driving circuit which in turn governed by using micrcontroller.
I rigged this circuit on a bread board and found that MOSFET STW34NM60N heat too much. (loadd 250W and input230V,50Hz)
I need your help to see What Mosfet can I choose and how do I calculate heatSink parameters forit. Online tutorials for heating dissipation shows formulae for switching MOSFETS, but here driving technique involves just switching on at a particular phase every half cycle based on dimming requirement.
Edit : I just realized, I posted this question Microcontroller section, Can anyone move it to Power Electronics Section please?
--- Updated ---
