MOSFET as Load switch
suryakant
Member level 5
Member level 5
India
mosfet load switch
Hi all,
I am using MOSFET to switch on/off supply to one section of my circuit. Supply voltage is 3.3V
The circuit is attached here.
When PS_Control is HIGH, I get 3.3V.
But, when PS_Control is low, still I am getting approximately 1V at the output. But i want the voltage to be zero. Whats the reason for this? Do I need to modify the circuit?
Thanks.
load switch
When the MOSFET is OFF Test-Point VL_3.3V is floating .. and you have a tiny leakage current ..
Try to add a "dummy" load of, say, 100kΩ that will pull the voltage down to 0V ..
Rgds,
IanP
mosfet as a switch
Hi IanP,
Actually load is 2 op-amps LMV324. I also tried to put dummy load, but no help!!!
Its still at about 1V.
But if I replace BJT by N channel MOSFET, it works fine......
I am just wondering what would be the reason.
mosfet switch
Either the real circuit is different from your schematics, PS_CONTROL is above 0.6V in low state or the transistor is defective.
Re: mosfet as a switch
Hi IanP,
Hi Suryakant,
can you put the schematic with thr BJT replaced with n-channel Mosfet?
Thank you a lot, Antonio
Unlike bipolar transistors, power MOSFETs have a considerable
gate capacitance that must be charged beyond the threshold
voltage, VGS(TH)
, to achieve turn-on. The gate driver must provide
a high enough output current to charge the equivalent gate capacitance, CEI
, within the time required by the system design.
https://ww1.microchip.com/downloads/en/AppNotes/00786a.pdf
