MOSFET AS A SWITCH FOR RELAY -- ARE DIODES NEEDED?
pfaisalbe
Junior Member level 2
United Kingdom
MOSFET AS A SWITCH
Hi
I wish to use MOSFET as a switch using electromechanical relays. I don't have the relay specification at this point. I came to know that , to avoid back emf I need to use freewheeling diode. I have found sample circuits as well. I will use PC parallel port to control the gate.
I am stucked in the design part.
I know that Rds and power dissipation parameters of MOSFET are necessary.Apart from that what are the other parameters i need to know for designing this circuit?
How to choose a Freewheeling diode fora particular inductive load ?
Please help
Thanks in advance
Faisal
MOSFET AS A SWITCH
Modern MOSFETS hase onchip diodes...
You must check for sufficient Uds & Ids values, select your appropiated package.
If you will select a "Logic Fet" (Ugs threshold at 2V)_it will direct controllable width your general logic...
#1230960
K.
    pfaisalbe
