Moscap in loop filter
majormac
Newbie level 2
Newbie level 2
Has anyone used moscap in a PLL loop filter? High capcitance per unit area is attractive. But I am worried about gate leakage current.
dont worry about it.
the leakage is very small.
Make shure that the cap variation over voltage does lead to PLL instability!
If <=.13um process, be aware of leakage current. Use high-vt device or varactor or metal cap.
If .18u or above, no problem.
i thought that hvt or lvt devices have the same oxide thickness, which means same gate leakage. 2V devices would be less leaky comparing to 1V devices which have thinner oxide...
