MOS Rectifier Test Circuit
HarryH00t
Newbie level 5
Newbie level 5
Hi guys,
I'm designing a MOS Rectifier for a RFID like application. I'm about to test some different structures, first of all the four transistor cell. I'm using cadence virtuoso for simulations. The goal is to load the load capacitance Cl with the rectifier. The rectifier gets the input signal over an inductive coupling. You can see my testcircuit in the picture. My input frequency is 13.56MHz, the RLC networks should have this resonant frequency. Vp and Vp- are the differential inputs of my rectifier. Vl is my low output, Vh is my high output.
The problem I'm facing right now is that I get a lot of errors when I'm trying to simulate the circuit. When I'm simulating with a small load capacitance (1pF) it seems to work (transient to 1ms) ok, but if I increase the capacitance (goal is about 1uF) I get a lots of errors. They all seem to be convergence errors or zero diagonales found in the jacobian at Vp. I don't really now where this problem comes from.
The thing I'm not shure about is where I have to put the ground terminals. I have one in the source circuit, but I don't think I should use one in the circuit of my transponder, since this would be equal to a direct connection from my source to my transponder(?).
I hope you can help me out.
Greetings, Harry
I'm designing a high efficiency rectifier.Could you please attach the schematic of the 4-T CMOS differential rectifier ( the symbol which is there in the test- circuit) and tell me the simulation analysis of the same. I'd be really grateful.
Thanks!:smile:
Saoni
Wow, it's been a while ^^
I've attached the schematic. Simulation results were basically that its working ;) And especially for my purpose, with low input voltages, was working best.
If you are going for high efficiency, you may want to try a Diode based rectifier with ultra low power Mos Diodes. If you have access to IEEE papers, i could also recommend some.
So long
Harry
Anyway, you should put a ground to your tansponder I think. If not there is no path for your current to flow. And it is not equal to a direct connection from source to your tansponder.
Hey Harry,
Thanks :) and yes..I have access to IEEE papers and I'd be glad to have your recommendations.
Saoni
