[SOLVED] Monte Carlo - no results
skoda
Junior Member level 3
I do Monte Carlo analysis to my Bandgap project, in this simulation I'm interreste in Opamp parametetrs Dc Gain,PM etc....
But as you can see on picture I have 100run but no sigmas no results no distribution. It looks like Monte Carlo doesnt change any parameter and do 100times same thing.I'm sure that library is defined.
Has anyone know some solutions ?
In the "model library setup window", ensure that you have the right "section" (this could be called "mc", depending on the kit you are using). Add this section for all libraries you want MC applied to.
Regards,
RG
Reactions: skoda
    skoda
Hi gag2000,
thanks! I need to set stat model lib. instead of SS,FF etc...
Everyting is fine now. :]
