renatoabner
Newbie level 3
I need to evaluate a model of a monopole antenna with the insertion of an infinite ground plane instead of the plane with finite dimensions. In CST i put the infinite plane in the determination of the boundary conditions with Et = 0, but in this case I have to use a discrete port instead of a waveguide port. This is the problem: The discrete port needs to be set at two points, one at the base of the monopole and the other on the ground plane, but the ground plane and monopole are at the same level (z = 0). How should I do this simulation?
Thanks.
Thanks.
