Monopole antenna over very small ground plane return loss improvement..
hozaifa
Hi, I need little help here, I am simulating this dual band antenna from a reference paper, I have attached the original design return loss with ground plane of 200*150 mm, and the antenna itself is 9x6 mm. my job is to attach this antenna to 19x12 mm ground plane and add two more resonances to it, to cover wifi 6E band (2.4-2.48 & 5.15-7.125). after introducing the new ground plane I notice there is deeper return loss in the higher band (which is good)and very high return loss at 2.44 GHz band (refer to the attached plot)…can anyone explain to me why that happen ..?????? and how I could get better matching at 2.44 GHz in this case without affecting the other bands..???? and also the best ways to add the other two resonance at 6.16 GHz and also at 6.9 GHz or maybe one wide band resonance .. (refer to the attached plots) …???????????
  • VERY SMALL SIZE PRINTED MONOPOLE with chip loaded.pdf
