Monomer & Polymer
Tinamuline
Member level 2
Member level 2
I would appreciate it if someone could tell me whether it is a physical change or chemicla change when monomer changes to polymer through the process of polymerisation. Most chemistry textbooks mentioned that it is a chemical change because the chemcial properties of polymer and monomer are totally different from each other. However, will there be any exception?
Please help.
Please help.
Based on my fundamental chemistry knowledge, I think there is no exception.
Let take 2 examples.
Addition polymerization
The polymerization from ethene to polyethene has changed the double bond in ethene into single bond. So, there is chemical change.
Condensation polymerization
1,6-diaminohexane and hexanedioic acid will react to form nylon under polymerization. However, nylon has a amide group while the monomer has no. So, there is also chemical change.
