cupoftea
Advanced Member level 6
Above 1KW , its best to have NTC’s glued to your power mosfets/IGBTs, and then gradually reduce the power throughput of the converter if the fets get too warm.
https://www.farnell.com/datasheets/3155179.pdf
NTC is best for this, because you can put say 4mA through it, and get a low noise reading out of this, as long as the wiring to the NTC is twisted.
Would you agree?...or is there a better way of monitoring FET temperatures?
