sawwa7
Full Member level 6
- Joined
- Oct 30, 2004
- Messages
- 332
- Helped
- 63
- Reputation
- 126
- Reaction score
- 31
- Trophy points
- 1,308
- Activity points
- 2,697
ibm6547
hi all colleagues
i have this IBM 6547-2BN built on samsung chassis CKB5237L which is dead apart from the power green led blinking once a second (nearly) and the relay clicking on power up . All the supply reails are comming correct and i can measure 50V on Collectors of both Q503 and Q406 , couldn't find any short horizontal area , all the supply rails of power supply are comming correct , 50V,80V,13V,7V,-12V .. all are ok except the missing 12V which comming from pin 2 of IC603 which measures about 1.1V and was disabled by Q604 (suspended by MCU) , if i disconnect Q604 base the 12V commes up again wich reveals non-faulty IC 603 , checking both Hsync and Vsync inputs @ pins 24 and 15 of IC 202(MCU) , proved they are present , also they come out of pins 21 and 20 of MCU , i have ocsillator activities around the crystal pins which reavel a working oscillator and crystal .
the supply voltage to MCU is 5.5 to 5.6 V @ pin 10 and there's 5.5V also present @ pin 25 of MCU , the supply voltage is regulated by IC600 which drops down the 13V supply rail to 5V for micon .. i couldn't find anything wrong or missing ??!!
one more thing i've noticed is pin 12 of MCU , H-Protect is high (5 to 6V) ,this indicates an OCP mode , when i disabled this , the HOT Q503 got very hot and no raster appeared .. does this means a faulty FBT?
any help or hint would be greatly appreciated
regards
Added after 5 hours 18 minutes:
hi again
here's the service manual for this monitor in case someone needs it or wanna have a look to help
Regards
hi all colleagues
regards
hi again
Regards
