astroman01
Newbie
Hello everyone, I have only recently started learning about transistor electronics, I mostly did Arduino and ESP32 projects. I have designed a simple momentaty switch circuit that when you press the button, the circuit outputs 12V and when you press the button again, it outputs 0V. The power is supply is 12V 1000mA. I used the IRFZ44N mosfet and BC558A transistor. The capacitor is a 2.2uF tantalum cap. The resisor values show on the schematic. I have build the circuit on a breadboard. I think there may be a mistake somewhere, all the legs of the transistor and mosfet show 12v whether you push the button of the switch of not. I have attached the schematic and a photo of my breadboard circuit. The momentary switch has 4 channels and then the blue wire is the MASSE (which is ground). I have used the green wire as in this circuit which is channel 3. Any advice would be appreciated.
