Modulus Arithmetic in Assembly Language?
illucius
Newbie level 6
Newbie level 6
assembly modulus
Just wondering... does anybody know a quick little code that can perform modulus arithmetic?
mod in assembly
what do you mean with modulus arithmetic ?
Do you mean of m = |m| ?
modulus assembly
Sorry, I meant perform the modulus of a number. Just like 3%5 = 3 in C, but in assembly language.
asm modulus
Basically you subtract the denominator from the numerator until the denominator is larger than what is left of the numerator. The resulting numerator is the modulus. The shortcut is to shift the denominator to where the next shift will make it larger than the numerator. and subtract this from the numerator. 3 shifts will be 2^3 or the same as subtracting the denominator from the numerator 8 times. You keep doing this shifting and subtracting until the denominator is greater than the remaining numerator. (Remember that zero shifts is still 2^0 = 1) The addition of the 2^shift1 + 2^shift2... + 2^shiftN will be the answer. The remaining numerator will be the modulus. Try doing it in a high level lanquage first, then do it in assembly. BTW, many micros that have an integer divide will have the result in one register and the modulus in another register, so it's already done for you.
And remember that in binary 2^n is the same as 1<<n
Added: Here is a sample in VB.NET
Module Module1
    Public Structure ModDivide
        Dim result As Integer
        Dim modulus As Integer
    End Structure
    Public Function DoMod(ByVal num As Integer, ByVal den As Integer) As ModDivide
        Dim shifts, dentmp As Integer
        Dim ans As Integer
        ans = 0
        While num >= den
            dentmp = den
            shifts = 0
            While (dentmp << shifts) <= num
                shifts = shifts + 1
            End While
            shifts = shifts - 1
            num = num - (dentmp << (shifts))
            ans = ans + (1 << shifts)
        End While
        DoMod.result = ans
        DoMod.modulus = num
    End Function
End Module
Then I made a form (Form1) with a textbox (tb1) that will output the answer when
the textbox is clicked on:
Public Class Form1
    Private Sub tb1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles tb1.Click
        Dim x As ModDivide
        x = DoMod(3421, 65)
        tb1.Text = x.result.ToString + "  " + x.modulus.ToString
    End Sub
End Class
