Modifying this design: the increase of voltage range
somf0872
Member level 5
Member level 5
Modifying this Design
Hi everybody,
Share some solid idea to increase the voltage output range in this design. I mean instead of getting 0 to 4.096V ............... I need to modify it for 0 to 15V.
Any comments??
--X--
you should :
- increase supply voltage to opamp (check that it supports more than +-15 V supply and what voltage on supply should be set to get 15 output without saturation , if necessary replace it with
suitable one )
- decrease R2 to 10 kOm
- tune opamp output by R3 to 15 V when max output set in DAC.
Re: Modifying this Design
Can u pls explain how one can do this calculation for the values u mentioned?
I mean incresing supply voltage makes the sense. But how can one calculate the other parameters to set?
--X--
above i roughly estimated R2 values but more less strict calculation could be done as below :
opamp gain when working in non inverting mode = 1 + R4/(R2 + R3) . Now lets calculate everything for trimmer resistance in middle position when R3 = R3/2 to make sure that we will have a oportunity to change voltage down and upwards . The gain will be R4/(R2 + R3/2) = 3.29 . Assuming that DAC provides for max output 4.096 V , we need to increase gain 15/4.096 times =~ 3.66 times so new gain is to be 3.66*3.29 =~ 12.04
the negative feedback coefficient could be calculated as :
12.04 - 1 = R4/(R2 + R3/2)
if R4 is to be unchanged
R2 + R3/2 = R4/11.04 = 9.05 kOm
As gain increases you can decrease value of R3 down to 3 kOm then can use R2 = 7.5 kOm and R3 = 3 kOm
    somf0872
Thanks a lot for ur help!!
Pls also see the following attachement. If I used the same DAC in this way ...... I mean having refrence voltage of 15V and then taking Vo as mentioned in the formula. I am just not able to find out that will this circuit be able to give around 300mA???
As the DAC can go max. to 50mA ?????
Any idea how can I get around 300mA at output.
Note: I saw OP77 datasheet but couldn't find any current ratings at output ..!!
--X--
the simplest way is to add voltage follower on BJT directly to opamp output and taking feedback from its emitter. But that requires low ohmic resistor and dissipates a lot power
or possible to add push-pull like here :
http://www.ecircuitcenter.com/Circuits/pushpull/pushpull.htm
Of course this circuit works best when biased for class A.
there are also other ways like here :
For practical circuit look to "Opamp for everyone" TI's application note under clause called something like - increase opamp otput voltage and current . (clause 14) . The doc should be available here or from inet .
