It is a modified guitar effect SansAMP GT2 with mids control, emiter follower at the output and with input modification – giving the signal from the first follower to the „distortion” system. There is also an additional effect setting (with 4-position switch).
Housing was made of cable conduit – it was cut, bent and soldered. Panel was designed in FrontDesigner. Slide potentiometers are not typical for a distortion.
Chips:
- TL082CP at the input x1
- TLC272CP for the distortion x2
- uPC1458C for the equalizer x2
The PCB was made in „almost thermal transfer method”. Top and bottom of the PCB was printed, then glued on a cardboard, holes were made using a needle. Then the components were placed on the PCB and linked together with protruding wires.
Pictures:
Link to original thread (useful attachment) - Efekt gitarowy SansAMP GT2 - moja wlasna wersja
