g.s.javed
Member level 1
Search:
This facility allows us to search for desired information from the entire data base.
Is there a tag system of a better search method than the one present that could be used here.
For Eg: If search for "Class A amplifier" is given, the search function does not take the entire phrase in its search.
It takes "Class" ,"Amplifier" ,etc individually.
Can a search be done for multiple keywords (present in the same post or discussion)?
If this is possible then I personally feel the need for putting up a new (repetitive ...) question can be removed.(Which I usually end up doing, after searching for them. Thankfully they, too, are also answered promptly)
I Humbly request the moderators and the senior members of this forum to look into this possibility. It also improves the usage.
Thank you.
P.S: I have also looked into the "Search query page". I am writing it after using that page too.
Javed
Thank you.
Javed
