Modelsim - How to disable timing check for certain module?
idwwwoqq808
Newbie
I use Modelsim DE 10.6c to run gate level simulation. Some synchronizers are added to my original design since it uses two clocks with different frequencies. I want to disable timing check only for these synchronizers.
Some threads from other forums said that we can use "tcheck_set" command but this command is not supported any more. I tried to run "tcheck_set" and Modelsim can not recognize this command.
Can anyone tell me how to do this in latest Modelsim?
