modelsim 5.6b in win200 sp3 - error
tlp71@hotmail.com
Full Member level 4
Full Member level 4
help whit modelsim
hi.
i work whit modelsim 5.6b in win200 sp3.
the license is ok alla chek is good but when i tri to simulate modelsim shoutdown whitout error.
can anybody hel me?
thanks.
g.
Have you checked ALL steps with the licensing wizard?
After shutdown, take a look at the log file, perhaps you find some info there
MODELSIM
This happens if license is not matching with the version of modelsim. There is surely a problem with ur license... check it out... Even in license wizard...u will not find anything...try with other license..
ms
I had the same problem. Replace lmgrd326.dll with the patched one.
Did you see exmaple Code?
Maybe, is there a $exit code?
no i don't have $exit code.
i try to make step by step and when i invoche the vsim command whit the rights argoument modelsim shout down.
where is the log file?
i dont'find it. maybe that i searched it not very well.
bye.
G
The lic can be checked by licensing wizard not mearning it is OK ! Check the hostid match your computer !
Seems you didn’t manage to get it work. Check your PM. Please keep me informed if that file solved your problem (by PM).
It is a licensing problem. I remember once I have to play with registry to fix it.
now i can simullate.
thanks to all for you help.
i hope to compensate you r help.
bye.
G
I have same problem with modelsim
Would you please help me with the same problem?
My modelsim is 5.6a,
