Models of decoupling capacitors
engr_joni_ee
Advanced Member level 3
I am looking for models of SMD ceramic de-coupling capacitors that defines ESL and ESR in different packages like 0603, 0805, 1206 for different capacitance. Do we have a database or online calculator to find these models ?
@danadakk, I am not sure if I would get the model parameters I am looking for. Do you know if the link you provided can also find ESL, ESR for capacitors in different SMD packages ? I have attached a datasheet. How can I find ESR and ESL of that capacitor ?
  • C0603X102J5GACAUTO.pdf
If you consider the model to be a
* capacitor
* a stray L in series
* and an R (ESR) in series.
Then you have: F_res = 1/ ( 2 x Pi x sqrt(L x C))
C is given, f_res from the chart is about 200MHz.
So you can solve the equation.
Also at resonance (frequency) there is no impedance, pure ohmic resistance = ESR.
So if you wanr ESR then just read the chart for ESR at f_res
For sure there are more complex models, then finding out the values is more complicated
Edit: corrected formula (green)
Klaus
This means that ESR is the lowest value at the f_res in the impedance plot.
The ESL has to be found using f_res = 1/sqrt(L x C), where f_res is the resonant frequent, C is known and then we can find the value of L which is ESL. This means that we can't find the ESL directly from the inductance graph, right ?
First: I made a mistake in my previous post:
f_res = 1/ ( 2 x Pi x Sqrt(L x C)).
(I missed to show the green part. I´ll try to correct this in the other post)
As said, it depends on the model you use. The lowest value in the impedance plot is a measure of all dissipated power. So if you have HF loss in the dielectric (or else where) then there is a difference between ESR and the lowest graph value.
Yes, try. And compare the values.
Graphs:
Now I did recognize that there is an ESR graph. Here one can see that the ESR @ f_res is lower than the impedance, which makes sense because of the existance of other losses.
What´s unclear to me, why the ESR should be in the region of 200 Ohms at 1kHz.
Not that this matters much - it still is more than 2 decades below the impedance. But I did not expect this.
Klaus
Btw: did you try the "K-SIM" link in the datasheet?
L from inductance graph and fres should give similar results. Did you notice that Kemet K-SIM tool also generates SPICE models?
ESR and ESL in Capacitors :
Regards, Dana.
