renguo
Newbie level 6
I want to model an op-amp in simpower systems but I can't seem to make it work. I've read from one forum to use an adder and connect it to a gain block then using s-ps converter, but still simulink won't let me connect the s-ps block to the simpower block.
You can check out the screenshot below:
I know this is very simple but I really have no idea. Please help.
I have tried using simscape instead since that system has an op-amp block but the simulation is extremely slow and the output is not what I expected it to be. So my options are either
1. to model an op-amp in simpowersystems, or
2. use the op-amp or other blocks in simelectronics and interface it in simpowersystems.
I have no idea how to go about with either of the two options, any help would be highly appreciated. Thank you very much!
