jolopez
Newbie level 3
Hello everyone,
I'm here to ask you one question. I have a electronic system with Modbus integrated working perfectly for several months. In this PCB I need 2 grounds (one Modbus dedicated). The fact is the system I'm using to isolate Modbus is quite expensive. I'm using this IC:
Analog ADM2587. Its great because it has auto voltage source to isolate Modbus.
Now I'm looking for another way to make an isolate Modbus design. I have some options in mind.
1. Use IC Texas ISO3080 (Isolated RS-485 transceiver). Problem here is I need to get a new voltage source. I have thinking to use a DC-DC converter, but options I see are expensive (DC-DC). And isolated transceivers is not the cheaper I would like...
2. Use IC Texas SN65176 (Differential Bus Transceiver) and digital isolator. This is the "best" option I think. Problem again, I need another voltage source. I have not never worked with digital isolator but Its not a problem. Its a very cheap solution.
As you can see I'm trying to get the same with less cost, designing as in old times.
So, here is the quesiton. Is there another option I dont have in mind?
and, how can I get another source voltage to use with these transceivers? As I wrote, I was thinking in DC-DC converter. Use a trasformer with 3 secondary I think it's bad choice (if it exist), and to use one more transformer increase the cost.
Thanks in advance :wink:
Best regards,
Best regards,
