[SOLVED] MOC3021 alternatives with array
Austonpramodh
Newbie level 3
Newbie level 3
Udupi,karnataka
I am new to optocouplers and traics....Cant find any alternative to MOC3021..
i need an optocoupler with array to work with multiple BT136....An iC with mutiple optocouplers to switch multiple BT136...
yep it seems that fairchild never made an array version of their popular moc30xx...
you have the TLP525G−4 from toshiba that could be ok, but it's a triac driver, but not a zero cross detector.
https://toshiba.semicon-storage.com/info/docget.jsp?did=16937&prodName=TLP525G
well as the moc3021 is not zerocross, this toshiba is the way to go.
the "-2" with 2 channels is available at mouser and digikey
but the "-4" does not seems to be available anywhere ?
Reactions: FvM
    FvM
Did you go to manufacturers and distributors and use their selection guides?
What are the results?
Klaus
