MMSIM 7 error connected with license file
ashi
Member level 4
Member level 4
Egypt
mmsim7
I recently had installed MMSIM 7
But I had a problem with it, when running any simulation I got this error
6:36:12 (cdslmd) DENIED: "Virtuoso_Spectre" root@localhost.localdomain (License server system does not support this version of this feature. (-25,334))
6:36:12 (cdslmd) DENIED: "32500" root@localhost.localdomain (License server system does not support this version of this feature. (-25,334))
6:36:12 (cdslmd) DENIED: "Virtuoso_Multi_mode_Simulation" root@localhost.localdomain [Spectre L] (License server system does not support this version of this feature. (-25,334))
6:36:12 (cdslmd) UNSUPPORTED: "Virtuoso_Spectre_XL" (PORT_AT_HOST_PLUS ) root@localhost.localdomain (License server system does not support this feature. (-18,327))
6:36:12 (cdslmd) UNSUPPORTED: "Virtuoso_Spectre_GXL" (PORT_AT_HOST_PLUS ) root@localhost.localdomain (License server system does not support this feature. (-18,327))
Although My license file support Virtuoso_Multi_mode_Simulation feature, I checked that with lmstat -a.
Can any one help me with this problem
cdslmd
This message " (License server system does not support this version of this feature. (-25,334))" tells you the problem.
You have a license but for older versions of the programs.
You have two options: 1) use older versions of the programs or 2) get a valid license for the versions you are using.
    ashi
license server does not support this feature
Ok
And how to know which version will work with the license I have.
mmsim7 linux
In your license file you will have lines for each feature and it will be something like this
FEATURE Virtuoso_Spectre cdslmd 6.200 ......
If I'm not wrong the number you see there is the highest version number of that program/feature you can use.
Don't bother changing that number because you will just invalidate that feature because the signature that comes after that will not match the version number.
    ashi
