MMBT2222a S parameter file?
biff44
Advanced Member level 6
New England, USA
mmbt2222a pspice
Anyone have and S2P file for an MMBT2222a transistor? I can't believe it, but I can not find one anywhere on the web.
The S-parameters (S2P file) are easily derived from a two port analysis using the MMBT2222a SPICE model below and at a suitable DC-bias.
What is the frequency range of your MMBT2222a design? Bias: is IC 10 mA and VCE 10 V sufficient?
MMBT2222a SPICE model:
NPN (Is=14.34f Xti=3 Eg=1.11 Vaf=74.03 Bf=255.9 Ne=1.307 Ise=14.34f Ikf=.2847 Xtb=1.5 Br=6.092 Nc=2 Isc=0
Ikr=0 Rc=1 Cjc=7.306p Mjc=.3416 Vjc=.75 Fc=.5 Cje=22.01p Mje=.377 Vje=.75 Tr=46.91n Tf=411.1p Itf=.6
Vtf=1.7 Xtf=3 Rb=10)
This transistor is LF type (Ft=300MHz). For such transistors manufacturers do not provide S parameters data.
Here are the S-parameters, extracted from the SPICE model. 1 to 50 MHz @ 6 V, 30 mA. The zip file contains the S2P-file.
