mkroC 4 Digits example
janosandi
Full Member level 4
Full Member level 4
hello Guys
im new to MikroC & by learning it from examples i've got nothing
i need an example of 4 digit which have 4 variables i can use for 4 digits seperately
thx for help
learn from here select which controller you use and https://learn.mikroe.com/ebooks/
i've used "pic programming in C & the first example i've tried to compile has errors then on mikroe forum one of the mikroE team replied to a message tht i've posted about the example errors & have sent me an corrected example as she said but it idnt work also
so its such trusted Book really to start learning of
looking for someone worked with it to help me
if you work with it you can check example9 which had errors
so how they think anyone can learn anything from tht book
thx for your reply
As soon you will show your code and schematics, as far you will get any usefull help.
i've tried learning C from example9 :two digit led counter
but its not working even after correction of MikroE team
here is the schematic
/*Header******************************************************/
unsigned short mask(unsigned short num);
unsigned short digit_no, digit10, digit1, digit, i;
void interrupt() {
 if (digit_no==0) {
 PORTA = 0; // Turn off both displays
 PORTD = digit1; // Set mask for displaying ones on PORTD
 PORTA = 1; // Turn on display for ones (LSD)
 digit_no = 1;
 } else {
 PORTD = digit10; // Set mask for displaying tens on PORTD
 PORTA = 2; // Turn on display for tens (MSD)
 digit_no = 0;
 TMR0 = 0; // Reset counter TMRO
 INTCON = 0x20; // Bit T0IF=0, T0IE=1
void main() {
 OPTION_REG = 0x80; // Set timer TMR0
 TMR0 = 0;
 INTCON = 0xA0; // Disable interrupt PEIE,INTE,RBIE,T0IE
 TRISA = 0; // All port A pins are configured as outputs
 PORTD = 0; // Turn off all display segments
 TRISD = 0; // All port D pins are configured as outputs
 do {
 for (i = 0; i<=99; i++) { // Count from 0 to 99
 digit = i % 10u;
 digit1 = mask(digit); // Prepare mask for displaying ones
 digit = (char)(i / 10u) % 10u;
 digit10 = mask(digit); // Prepare mask for displaying tens
 Delay_ms(1000);
 } while (1); // Endless loop
& here is the corrected 1
void interrupt() {
 if (digit_no==0) {
 digit_no = 1;
 } else {
 digit_no = 0;
void main() {
 TMR0 = 0;
 do {
 for (i = 0; i <= 99; i++) { // Count from 0 to 99
 digit = i % 10u;
 Delay_ms(1000);
here is the segment mask
unsigned short mask(unsigned short num) {
switch (num) {
case 0 : return 0x3F;
case 1 : return 0x06;
case 2 : return 0x5B;
case 3 : return 0x4F;
case 4 : return 0x66;
case 5 : return 0x6D;
case 6 : return 0x7D;
case 7 : return 0x07;
case 8 : return 0x7F;
case 9 : return 0x6F;
if you want to help me i need 2 things
1:a good reference to learn embedded C for PIC with examples wil be great.
2:a working example of 4 digits which i can assign values to each digit by seperate virables.
all of your help will b appriciated
John
here is a link to my thread on mikroE forum
https://forum.mikroe.com/viewtopic.php?f=88&t=67533
After reviewing some of your messages I would suggest you first go and learn to program in C
before trying to learn to program embedded code.
I would suggest if you cannot recognise the obvious error in the code above that you
may be putting yourself and possibly others in danger.
Suggested course of action
1. Learn to program in C
2. Learn basic electronics
3. Learn how to tie the 2 together
4. Go back to Mikro and try again.
Trying to learn programming and electronics together
at the same time is probably a big mistake.
its ok as i guess
i've learned assembly & did alot of small projects before
learning is easy when you know what you need
would you plz tel me what kind of danger can i put others?
& what you mean by basic electronics ?
thx for reply anyway
Have you included the file mask.c into the project? If not, include it and bild it again.
Did the code built successfully? If not, post the screen shot of theoutput.
would you plz follow the link to my thread on MikroE Forum ?
i diid all of tht even there was an error in the code & they have fixed it but still not working
thx for reply
You need to use common cathode 7 Segments.
FYI,
At power up, all the ports are configured as input. Therefore,
will not do what you expect. (But here this is not the problem.). You need to set ports as output first then set them zero.
To find a solution plz tell what is the problem exactly. Did you simulated this or implemented this? What can u see on the segments etc...
If you implemented this in hardware there can be a problem in programming the fuses also.
its hard to find solution this way
i just need an example of 4 7segments which i can assign values to each one seperately
something like tht
Digit1 = O
Digit2 = P
Digit3 = E
Digit4 = N
start:
PORTA.0 = 1 //enable digit one
PORTB = Digit1
2ms delay
PORTB.0 = 0 //disable digit one
PORTB.1 = 0 //enable digit two
PORTB = Digit2
2ms delay
PORTB.1 = 0 //disable digit two
PORTB.1 = 0 //enable digit three
PORTB = Digit3
2ms delay
PORTB.0 = 0 //disable digit three
PORTB.1 = 0 //enable digit four
PORTB = Digit4
goto start
thx guys
Try to modify your code as per the hints below. Also add two more current sinking transistors driving from RA2 and RA3 respectively for two more 7 segment displays. Declare the variable 'i' as unsigned int instead of short.
ISR:
void interrupt() {
 if (digit_no==0) {
 digit_no = 1;
else if (digit_no == 1) {
 PORTD = digit2; // Set mask for displaying tens on PORTD
 digit_no = 2;
else if (digit_no == 3) {
 PORTD = digit3; // Set mask for displaying  hundreds  on PORTD
 PORTA = 4; // Turn on display for hundreds
 digit_no = 3;
else {
 PORTD = digit4; // Set mask for displaying thousands on PORTD
 PORTA = 8; // Turn on display for thousands
 digit_no = 0;
MAIN:
do {
 for (i = 0; i <= 9999; i++) { // Count from 0 to 9999
 digit = i % 10u;
 digit2 = mask(digit); // Prepare mask for displaying tens
digit = (char)(i / 100u) % 10u;
 digit3 = mask(digit); // Prepare mask for displaying hundreds
digit = (char)(i / 1000u) % 10u;
 digit4 = mask(digit); // Prepare mask for displaying thousands
 Delay_ms(1000);
 } while (1);
ISR:
void interrupt() {
 if (digit_no==0) {
 digit_no = 1;
 digit_no = 2;
 digit_no = 3;
else {
 digit_no = 0;
MAIN:
do {
 digit = i % 10u;
 Delay_ms(1000);
 } while (1);
thx
i've already did it tomorrow i'll send it here but ur code is very useful for me also
thx Guys
John
hello Guys
I've got 2 digit counter code from a friend which i've edit it & now it ok with 4 seperate virables
with this code OPEN is shown on 4digits
would you check if its ok ?
char select = 0, Digitt1, Digitt2, Digitt3, Digitt4;
unsigned char common_cathode_mask[21] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F, 0x77, 0x7C, 0x39, 0x5E, 0x79, 0x71, 0x73, 0x50, 0x5C, 0x37, 0x40};
//                                      0      ,1    ,2    ,3    ,4    ,5    ,6    ,7    ,8    ,9    ,A    ,b    ,C    ,d    ,E    ,F    ,P    ,r    ,o    ,N    ,-
//char digit[2];
char digit[4];
//Timer1
//Prescaler 1:1; TMR1 Preload = 63536; Actual Interrupt Time : 2 ms
//Place/Copy this part in declaration section
void InitTimer1() {
    //T1CON = 0x01;
    T1CON = 0x01;
    TMR1IF_bit = 0;
    TMR1H = 0xF8;
    TMR1L = 0x30;
    TMR1IE_bit = 1;
    INTCON = 0xC0;
void Interrupt(){
    if(TMR1IF_bit) {
      TMR1H = 0xF8;
      TMR1L = 0x30;
      PORTD = 0x00;
      //Enter your code here
      switch(select) {
          case 0:
                PORTC = digit[0];
                PORTD = 0x01;
                break;
          case 1:
                PORTC = digit[1];
                PORTD = 0x02;
                break;
          case 2:
                PORTC = digit[2];
                PORTD = 0x04;
                break;
          case 3:
                PORTC = digit[3];
                PORTD = 0x08;
                break;
      if(++select == 4)select = 0;
      TMR1IF_bit = 0;
void Dopen() {
     Digitt1 = 0;
     Digitt2 = 16;
     Digitt3 = 14;
     Digitt4 = 19;
     PORTB.RB5 = 1;
void main() {
    CMCON = 0x07;
    ADCON1 = 0x87;
    TRISA = 0x00;
    TRISB = 0x03;
    TRISC = 0x00;
    TRISD = 0x00;
    TRISE = 0x00;
    PORTA = 0x00;
    PORTB = 0x00;
    PORTC = 0x00;
    PORTD = 0x00;
    PORTE = 0x00;
    InitTimer1();
    Dopen();
         digit[0] = common_cathode_mask[Digitt1];
         digit[1] = common_cathode_mask[Digitt2];
         digit[2] = common_cathode_mask[Digitt3];
         digit[3] = common_cathode_mask[Digitt4];
I am not an expert in C. However, it seems the code is ok.
