Mixing C and assembler code for TI MSP430F149 controller
MagicSpark
Newbie level 5
Newbie level 5
I have assembler project based on the TI MSP430F149 controller. I need to convert it to C. Our approach is to mix assembler and C code together, and then slowly rewrite pieces of assembler code. So I have the following questions:
I've added C file to the project containing main() function. Do I have to take special care to redirect reset vector at 0xFFFEh to call main function or C compiler/linker will do that for me?
Obviously C code is converted to assembler and placed into CODE segment. I need to know whether that assembler code (from C) will be placed to separate CODE segment or to the existing CODE segment with existing assembler code?
I have COMMON segment in assembler code where interrupt vector is defined.
I assume that C compiler/linker will have to make necessary changes there in order to call main on reset (power on) interrupt. Should I leave reset vector undefined in assembler code? Should I define reset vector in C? How this will interact with existing interrupt vector ion COMMON segment in assembler code?
Thanks in advance
P.S. I use IAR workbench IDE
HI
Search TI site there are several program who written fro IAR for mixed C and ASM
Read the IAR user manuel to know more on how to use mixed C and ASM
Also in TI site there is application note show how to mix ASM and C
All the best
Bobi
