LandLack
Member level 3
I am putting a 10.35 dBm signal into a mixer; the datasheet tells me that the Conversion Loss of the device is 6.7dB for a Single-Side-Band (SSB). I have two questions:
1) The total power output of the mixer will be 6.6dBm, right? I ask this because I think that the output of this mixer is Double-Side-Band (DSB) by default, so the output power will be in dBm: Pin-6.7+3 = Pout . (tell me if it's wrong, please)
2)How may I use a SSB instead of DSB? Do I need to use a filter on the mixer's output (If yes, can you tell me how can I filter the carrier power of the unused sideband, which has the biggest contribution)?
If you have an answer to any of these question, please reply, even if you aren't sure. Thank you,
Best Regards,
LandLack
Best Regards,
LandLack
