mixer spurious analysis example
robismyname
Full Member level 6
Full Member level 6
Central Florida
I found an excel spur calculator endorse by microwave 101
On the notes tab of the tool there is an upconverting example provided where the the IF = 300-350MHz, LO = 500MHz and RF =800-850MHz
Question 1:
Can I use this spreadsheet if I had a downconversion example where IF = 315MHz and LO = 2086-2168?
Question 2:
The author says in his example on the notes tab that " at 325MHz in we start getting 5th order products that may be a problem."
At 325 MHz the 5th order spur highlighted is at 875MHz, how is this a problem?
Arent all the spur issues the ones that fall within 800-850MHz?
Please explain.......
